power input 24v
Is it possible to use 24v for power input instead of 12v?
no, A32 only use dc12v power supply, because relay coin is dc12v version.
(05-22-2024, 10:04 PM)admin Wrote: no, A32 only use dc12v power supply, because relay coin is dc12v version.
but here I asked for KC868-A16 ....
A16 support DC12-24V for power supply.
Hi. I just ordered an A16 as well and I had the same  question. The image shows 12/24V for the DC Input for the digital outputs. But only 12V for Power Input.
So just to confirm - the Power Input for the board itself can also be 24, correct?
[Image: KC868-A16-1_03.jpg]
Thanks in advance.
yes, you are right. you can use DC12v for all terminal or DC24v for all terminal (include power input port).
(07-10-2024, 09:50 PM)admin Wrote: yes, you are right. you can use DC12v for all terminal or DC24v for all terminal (include power input port).
Is it possible to
1. supply the A16 with 12 V and power one Terminal with 12 V and the other Terminal with 24 V?
2. supply the A16 with 24 V and power one Terminal with 12 V and the other Terminal with 24 V?
I would like to connect different devices, some use 12 V, some use 24 V
both ok, just two power supply GROUND should connect together.
