10-10-2021, 08:18 AM
(This post was last modified: 10-10-2021, 08:46 AM by superG.
Edit Reason: Add analysis for terminal board
For my setup; I want to use an AC/DC 12V with an integrated battery (Kincony used in combination of my alarm system and domotic modules)
I was thinking to use the MeanWell DRC-40A but the voltage is slightly above 12V.
Is the input tolerant to 13V (voltage of the battery in float mode).
I have:
- K868-32b
- Switch terminal board 2.1
Edit:
- Terminal board 2.1 is OK as it use the ST 78M05 linear circuit power which has a 35V Max absolute input
- That also means the chip will dissipate more power to drop down to 5V ( 16% more)
Thanks
I have:
- K868-32b
Edit:
Thanks
