KCSv3 ADC threshold does nothing with Home Assistant MQTT
Hi. Does the ADC threshold not apply to Home Assistant MQTT? For testing, my CH1 is around 1430 to 1450, value does not go above 1450. I put 100 so it should update in MQTT the value when it go above 1500 correct? But in Home Assistant MQTT the value still update every 2 second between 1430 to 1450.
The drop in the graph is when I try reboot the board to see if threshold apply after reboot. Still same.
you can replace "100" with "10". have a testing.
Still same update every 1-2 second
after saved setting, do you have re power on of your board?
