F16 relay stopped functioning
I have had the F16 for awhile now but over the past few weeks, the relays suddenly stopped working. I can control the relay functions in HA and can hear the click sound of the relay but the lights remained on (the relays are connected to light circuit). When I touch the board it is very hot.Is this normal? How to fix this issue?
can you take a video of your problem.
I cant upload the video directly here. So here's a link to the video
https://drive.google.com/file/d/1TZ8Rmda...sp=sharing
I can hear relay click but light still on. The F16 is also hot to touch
you can disconnect relay output wire with load. use multi meter to relay5, when turn on/off, then COM and NO whether is CLOSE and OPEN. just test without load.
