03-01-2023, 03:22 AM
Can H32B pro use the new yam.l file that you provide in here?
Thanks
Regards,
Aliman
Thanks
Regards,
Aliman
home assistant RC 2022.6 mqtt config update for configuration.yaml
Thanks Regards, Aliman
03-01-2023, 04:00 AM
sure, you can see sample config at here: https://www.kincony.com/kc868-h32b-integ...-mqtt.html
03-01-2023, 04:29 AM
(03-01-2023, 04:00 AM)admin Wrote: sure, you can see sample config at here: https://www.kincony.com/kc868-h32b-integ...-mqtt.html thank you for the fast respone. regards, Aliman
03-01-2023, 04:49 AM
you are welcome.
04-08-2023, 07:33 PM
(This post was last modified: 04-08-2023, 07:34 PM by Alex1987sar.)
hello
I use kc868-h32 via TCP\IP and this manual https://www.kincony.com/home-assistant-r...odule.html there is a problem whis a code how to solve it? HA says: nvalid config for [mqtt]: The 'broker' option near /config/configuration.yaml:19 has been removed, please remove it from your configuration for dictionary value @ data['mqtt']. Got {'broker': '127.0.0.1', 'port': 1883, 'discovery': True, 'discovery_prefix': 'homeassistant'}. (See /config/configuration.yaml, line 19).
04-09-2023, 12:14 AM
if you are using KC868-H32 old controller, it's not support MQTT. you can take a photo of your controller whole box. let me have a look.
04-09-2023, 04:35 AM
just remove the mqtt broker lines in configure.yaml file will be work fine.
04-09-2023, 04:50 AM
Now it works fine, thank you
I removed the following broker: 192.168.1.42 port: 1883 username: xxxxxx password: xxxxxxxx
04-09-2023, 05:36 AM
ok
| 2 Guest(s) |
