ESP32 RF
#41
I'm new to the ESP flashing. trying to follow instructions on this thread, flashing the ESP chip to receive RF output on the Arduino without success. Getting the attached error messages. I noticed that i don't have the option to reduce the baud rate lower than 115200.
.docx   Flash ESP.docx (Size: 719.64 KB / Downloads: 771)
what you want to do? use by "KCS" firmware? or use by home assistant? or ???
(03-29-2023, 12:17 AM)admin Wrote: what you want to do? use by "KCS" firmware? or use by home assistant? or ???
Use with Home Assistant to capture RF signal for TV etc. and control thereafter.
you can use ESPHome, just config IR receiver or RF reciever gpio pin. make sure your product have IR or RF hardware function.
(03-29-2023, 09:56 AM)admin Wrote: you can use ESPHome, just config IR receiver or RF reciever gpio pin. make sure your product have IR or RF hardware function.
How do I make sure that the KC868-Server has IR or RF hardware function?
I have tried different configs using different pins (22, 36) in each instant. this is for Samsung TV.
Here is config 1 below for ESPHome:
captive_portal:
remote_receiver:
  pin: 36
  dump: all
  # Settings to optimize recognition of RF devices
  tolerance: 50%
  filter: 250us
  idle: 4ms
  buffer_size: 2kb
Here is config 2 below for ESPHome:
captive_portal:
web_server:
  port: 80
remote_receiver:
    number: 23
    inverted: True
  dump: all
remote_transmitter:
    number: 22
  carrier_duty_percent: 50%
  - platform: template
    turn_on_action:
      - remote_transmitter.transmit_nec:
          address: 0x00BD
          command: 0x807F
          repeat:
            times: 10
            wait_time: 50ms
    turn_off_action:
          address: 0x00BD
          command: 0x807F
          repeat:
            times: 10
            wait_time: 50ms
this is GPIOs for KC868-Server's ESP32 module:
IR receiver: GPIO22
IR sender: GPIO23
433MHz wireless receiver: GPIO13
here is details: https://www.kincony.com/forum/showthread.php?tid=1735
(03-30-2023, 10:49 AM)admin Wrote: this is GPIOs for KC868-Server's ESP32 module:
IR receiver: GPIO22
IR sender: GPIO23
Kindly share the .yaml
about the IR and RF you can see our other KC868-A series board, have demo yaml file on our forum.
(03-30-2023, 11:12 AM)admin Wrote: about the IR and RF you can see our other KC868-A series board, have demo yaml file on our forum.
I'm sorted. Thank You.
you are welcome.
