Kincony and Which warm flloor termostat would be better?
#11
(11-27-2023, 12:17 PM)admin Wrote: "when I turn on the heated floor through the button" -- which button? your own warm system's button? or H32B Pro's manual control button (KC868-AK's button)?
Do you suggest connecting the thermostat to the ac868-ak or to the ac-868h32 b pro?
your load connect to KC868-H32B Pro, KC868-AK also connect to KC868-H32B Pro for manual control way.
(11-27-2023, 10:39 PM)admin Wrote: your load connect to KC868-H32B Pro, KC868-AK also connect to KC868-H32B Pro for manual control way.
@admin: you have to take a look at underfloor heating solution in Europe, and implement something like that in your devices. Please see example:
https://saluscontrols.com/gb/
Also try to implement a solution with zigbee termostats, in a iftt scenario,
that work without internet. Also consider using ssr relays, as they are silent.
Thanks.
Consider using this kind of termostat (or any zigbee termostat) :
https://www.aliexpress.com/item/10050064...Redirect=y
your second link is a zigbee sensor, not termostat . do you want a zigbee sensor can automatic control another relay board?
(02-19-2024, 10:51 PM)admin Wrote: your second link is a zigbee sensor, not termostat . do you want a zigbee sensor can automatic control another relay board?
Consider a master relay board that has remote zigbee sensors that can control the on/off function for specific relays that control the underfloor heating colils and the gas boiler and pump.
Thanks.
Thanks.
Something like this:
https://www.aliexpress.com/item/10050058...ry_from%3A
