12-30-2021, 07:19 PM
Can you please confirm the following wiring of the RC snubber with a KC868-H32B for a furnace valve is OK ?
RC snubber wiring
12-30-2021, 11:33 PM
what's your valve work voltage?
12-31-2021, 06:49 AM
12-31-2021, 07:50 AM
RC snubber connect with valve's coin two point. Parallel with blue and purple wires
01-01-2022, 02:38 AM
correct. But your photo i think not show wholely? right line not deleted?
01-01-2022, 05:48 AM
01-01-2022, 05:59 AM
your diagram is right.
01-06-2022, 06:04 PM
(01-01-2022, 05:59 AM)admin Wrote: your diagram is right. The RC snubbers did not solve my issue: after less than 3 days with the Kincony RC snubbers installed as indicated in the above diagram, I ran into the same problem: the KC868-H32 MQTT stack stops responding for all relays, turning the Kincony device into a useless brick. ![]() ![]() Please advise.
01-07-2022, 12:14 AM
can you take big photo and upload a full diagram how you wire? your photo to smal , not easy to check.
« Next Oldest | Next Newest »
| 1 Guest(s) |
