KC868-A4 wiring diagram
Hello, how to wire( wire 0.5 ) a switch panel ? I use A4 with tasmota (...pin 36 39 27 14 ) k 1 k2 kcom to gnd d1 d2 d3 d4 of A4..thank you
yes, D1,D2,D3,D4 can use for switch buttons.
Good morning,
Let me explain better...I have its two-button switch.
Behind there are 5 contacts ( kc, k 1 k2 k3 k 4) and another 6 contacts ( dc gnd d1 d2 d3 d 4)... how should I connect these with the contacts d1 d2 d3 d4 of the kc868-A4?.. how and how many threads...thank you
let your ESP32 board relay output DC12v, then connect to your switch panel's D1,D2,D3,D4 , LED on switch panel will be ON/OFF by dc12v or 0V. which electronic level will ON, suggest you have a test, i am not see your switch panel photo, so i can't sure.
Thanks for the reply...I attach a copy of the back of the kincony 2-way switch...I have to connect it to the kincony kc868-a4...switch has: 5 contacts ( kc, k 1 k2 k3 k 4) and another 6 contacts ( dc gnd d1 d2 d3 d 4)... as you can see from the photo above there is the gnd of the kc868-a4 connected to the k-com of the switch.. then there is the k1 red wire of the switch connected to the a4 d2 and d1 of the kc8687-a4...and the k2 yellow wire connected to d3 of the kc868-a4
.pdf   kincony.pdf (Size: 103.97 KB / Downloads: 588)
.pdf   kicncony 2.pdf (Size: 112.84 KB / Downloads: 530)
(10-31-2023, 02:53 PM)fra6767ita Wrote: Thanks for the reply...I attach a copy of the back of the kincony 2-way switch...I have to connect it to the kincony kc868-a4...switch has: 5 contacts ( kc, k 1 k2 k3 k 4) and another 6 contacts ( dc gnd d1 d2 d3 d 4)... as you can see from the photo above there is the gnd of the kc868-a4 connected to the k-com of the switch.. then there is the k1 red wire of the switch connected to the a4 d2 and d1 of the kc8687-a4...and the k2 yellow wire connected to d3 of the kc868-a4
A4---GND  ---->switch  KCOM
A4---D1-------> switch  K1
A4---D2------->switch  k2
A4---D3------->switch  k3
A4---D4------->switch  k4
Ignore the switch D1 D2 D3 D4 GND and DC
Very good..now it works. Thank you, Have a nice day.
