Threads: 2
Hello, i see that the COLB is connected to the MQTT broker but i don't receive any data.
When i connect to the local pc software i see that the device working (have data).
What should i do?
Threads: 1,281
you should enable the "AutoReport" function in PC software firstly, then MQTT will have message auto upload.
Threads: 7
Did you managed to resolve your issue? I have the same situation. COLB send only data for digital sensors, not for temperature and analog sensors. Autoreport is turned on and after COLB restart sends data for a single time, then nothing (only digital sensor values).
Threads: 1,281
do you have set the threshold value firstly?
Threads: 1,281
use Node-Red can read energy meter and feedback to home assistant.
Threads: 1,281
it's not easy. need to write code. i think you can chose some wifi energy meter so that support MQTT directly.
