Threads: 10
Hi,several questions after I spent time on looking answers.
I lost access to my A8.
What are the S1 and S2 usage? On the schematics, both seems to do the same.
I press more than 10s S1, then S2.
I can connect to Kinc AP on 4.1
On the login page, I tried admin/null, admin/admin ,always login error.
I tried another board, same issue.
My 12v is 11,7. I guess its not a problem.
Please help
Thanks
Threads: 10
10-08-2025, 05:18 PM
(This post was last modified: 10-08-2025, 05:19 PM by philippe.)
Thanks,
I reloaded v2 kcs. on both boards. There are in AP mode, I can connect to their wifi, I get on my phone an ip address on sub segment .4, I can access the login page on IP 4.1, I use admin/admin and it stays on the login page.
Seems that the login /pass are accepted, as, if I use a different passwd, I have an error message (login pass incorrects).
Using the rj45, no problem, admin/admin is accepted and everything seems ok.
I have A8 v1.5 and V1.6 boards. I loaded the last kcs .14.
I tried the v3, but without success.
So strange that I cant login in wifi AP mode
Threads: 1,204
KC868-A8 only use by KCS v2, can't use by KCS v3, it's not ESP32-S3.
you already can login by admin / admin. how you change password and can't login?
take a photo of screen how you change password. and login window.
Threads: 10
10-09-2025, 04:05 AM
(This post was last modified: 10-09-2025, 04:12 AM by philippe.)
When I reset factory the board, I can connect when wired. I dont change the login detals.
Then, when I connect by wifi, I get the login page, fill admin admin , it cleard the login details, and no other page comes. If I put a different login, admin/anuything, I get the login details error message.
I tried to post a picture, but error message too long ( the picture is a small one). Anyway, it does not show anything more.
Threads: 1,204
can you take a photo or video , so that can understand you.
