» Members: 10,448
» Latest member: BennettTrujillo
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 568 online users.
» 0 Member(s) | 543 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
Photo How to boot home assistant with sd card on cm4?
Posted by: soethu - 09-25-2023, 05:11 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (1)
I'm new to Kincony. I installed home assistant on sd card and tried to boot on cm4 but it doesn't boot and showing as attached picture.
  KC868-H32B V5.08 firmware
Posted by: admin - 09-25-2023, 03:58 AM - Forum: News - Replies (24)
fixed bug for tuya connection with cloud server.
firmware download:
.zip   H32B_V508_230921.zip (Size: 134.93 KB / Downloads: 1321)
make sure your KC868-H32B CPU chip is AT32F403AVGT7.
if your board CPU is STM32F103VCT6 or GD32F103VCT6, there is no enough memory for new firmware update, they memory is 256K. new firmware is >300k, so can't use it.
  ESP32+LD2410 presence sensor
Posted by: bsubasi - 09-24-2023, 11:40 AM - Forum: Development - Replies (8)
hi,
What is your ESP32+LD2410 presence sensor product's description and purchasing links?
KC-PDZ-201 and LD2410 presence sensor  Can the product work with esp and wifi? Which firmware does it use?
  Application Condition: B - KC868-A4
Posted by: Als Santa - 09-23-2023, 10:56 AM - Forum: Apply for free sample product - No Replies
Hello, I am passionate about technology, that is why I became an engineer, I am from Colombia in South America, I would like technology to be available to everyone.
I have worked with home assistant and found that many applications can be made with their product due to its technical characteristics, which is why I would like to try it and publish these new and fast solutions based on KINCONY's IoT hardware. thank you so much
  Tasmota supported devices
Posted by: GabrielRR - 09-23-2023, 07:24 AM - Forum: Development - Replies (3)
Which from your products are fully compatible with tasmota firmware?
  ESP32 Energy Meter Relay Controller - KinCony M1 released
Posted by: admin - 09-22-2023, 11:57 PM - Forum: News - No Replies
We have designed ESP32 Energy Meter Relay Controller - KinCony M1 (ESP32 1 channel AC voltage and current energy monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. it use by BL0942 energy chip, support by ESPHome. the hardware have BL0942 sensor + 1CH DIGITAL INPUT port + 1CH ZMPT107-1 voltage sensor + Ethernet POE+ WiFi + Bluetooth + 30 Relay. It have I2C bus extender terminal.
[Image: M1-1_01.jpg]
[Image: M1-1_02.jpg]
[Image: M1-1_03.jpg]
[Image: M1-1_04.jpg]
  error instal A128
Posted by: Almhlws - 09-22-2023, 10:41 AM - Forum: KC868-A series and Uair Smart Controller - Replies (15)
Hi every one
when i try to instal A123, i get error
ERROR Serial port closed!
see attach
  Dead Board?
Posted by: grs56 - 09-22-2023, 06:11 AM - Forum: KC868-A8 - Replies (5)
I have a KC868-A8.
I Flashed it fine four days ago using ESP Home on windows 11.  The board is connected to a regulated switched-mode 12v supply.  I had started to program up a script to use as an aquaponics controller.  I had the following connected:
One dry contact on the first input
One TDS sensor on A1  (+4v)
One DS18B20 on S1
All was working well.  I left the board running overnight.
Came back this morning and noticed that it wasn't showing up in Home Assistant or responding to its IP address.
Power was still OK everywhere.
I have attempted to reflash using esphome webtools and using ESP flasher and your own
 tool from here:  ESP Module Flash Download Tools - Smart Home Automation | KinCony
I have rebooted and reinstalled the com port.
I have tried from my mac.
The Serial port is showing up on USB connection on both the mac and PC.
I have tried with a different USB cable.
I have confirmed I am able to flash other esp32 chips from the PC with no problem.
I have tried using the s1 and s1 as boot buttons.
My assumption is that the board is dead unless you have other advice?
config for reference:
I had yet to attach the Ph probe as I was building a voltage divider this morning. Also the Ultrasonic sensor requires some extra files for the build and i had yet to but those in the right place.
# Basic Config
  friendly_name: Greenwall
  encryption:
    key: !secret greenwall_api_key
ota:
wifi:
  ssid: !secret wifi_ssid
  domain: !secret local_domain
  ap:
    ssid: "Esphome-Web-E12294"
    password: "sJdgDQKbR936"
captive_portal:
web_server:
  port: 80
  auth:
    username: !secret web_server_username
    password: !secret gw_web_server_password
#ethernet:
#  type: LAN8720
#  mdc_pin: GPIO23
#  mdio_pin: GPIO18
#  clk_mode: GPIO17_OUT
#  phy_addr: 0
  - id: 'pcf8574_hub_out_1'  # for output channel 1-8
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8
  sda: 4
  scl: 5
# Individual outputs
      pcf8574: pcf8574_hub_out_1
    name: "Swirl Filter Pump"
# Inputs
# Binary
    name: "Tank Level Low"
    name: "Swirl Level Low"
    name: "Bio Level Low"
    name: "Tank Overflow"
# Digital
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
    #address: 0x1c0000031edd2a28 #replace with your sensor's ID
    index: 0
    name: "Water Temperature"
  - platform: ultrasonic
    trigger_pin: 13
    echo_pin: 32
    update_interval: 1s
    accuracy_decimals: 2
    filters:
    - lambda: return (1 - x + 0.03);
    - median:
        window_size: 20
        send_every: 10
    unit_of_measurement: "m^3"
# Analog
# pins 34/35
  # https://esphome.io/components/sensor/adc.html
  - platform: adc
    pin: 34
    update_interval: 1s
    unit_of_measurement: pH
    # https://esphome.io/components/sensor/ind...or-filters
    filters:
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 3
      # Measured voltage -> Actual pH (buffer solution)
      - calibrate_linear:
          - 0.59 -> 7.0
          - 0.71 -> 4.0
  - platform: adc
    pin: 35
    update_interval: 1s
    unit_of_measurement: ppm
    filters:
      - lambda: return (x * 1000);
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 3
      # Measured voltage -> Actual TDS (buffer solution)
      #- calibrate_linear:
      #    - 0.59 -> 7.0
      #    - 0.71 -> 4.0
  Nodered MQTT H32B
Posted by: abgran - 09-22-2023, 02:40 AM - Forum: KC868-HxB series Smart Controller - Replies (6)
How to read the state of value for H32B?
  KC868-E16S wiring diagram
Posted by: KinCony Support - 09-22-2023, 01:34 AM - Forum: KC868-E16S/E16P - No Replies
