» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 133 online users.
» 0 Member(s) | 114 Guest(s)
Applebot, AwarioBot, Baidu, Bing, Bytespider, Google, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  8 channel ethernet wifi relay module -KC868-H8B released
Posted by: admin - 11-12-2020, 01:02 AM - Forum: News - No Replies
We improved ethernet wifi relay module — KC868-H8B for smart home automation DIY.
3: Ethernet and WiFi module wokr mode control by setting buttons and have LEDs for show work status.
4: Add “COM”, “NO”, “NC” 3 ports for every relay output.
[Image: kc868-h8b_pix550.jpg]
[Image: kc868-h8b-details_04.jpg]
  Smartfarm solutions by KC868 Smart Controller
Posted by: admin - 11-10-2020, 01:46 AM - Forum: KC868-HxB series Smart Controller - No Replies
(Smart Power Distribution Box with inverter) For Fans:
1. Control fans for:
  --A. Turn ON/OFF power
  --B. Change fans’ speed (hight,mid,low)
2. Control fans by mobile phone,PC.
3. Supply two verison of software:
  --A. need internet for remote control
  --B. without internet for local control
4. Temperature and humidity automatic control fans:
  --A. E.g. Temperautre >35℃ Then fan speed=high
  --B. E.g. Temperautre <25℃ Then fan speed=low
  --C. E.g. humidity >85% Then fan speed=high
  --D. E.g. humidity <70% Then fan speed=mid
  All trigger conditions and fan control mode can be set by PC software. Automatic running locally without internet.
5. Inverter+Thermal Relay+ACB (air circuit breaker) connect to Fan Motor, So that any fan failure, inverter will shutdown for protection.
(Smart Power Distribution Box without inverter) For light and pump:
1.Control light or pump for Turn ON/OFF power
2.Control light or pump by mobile phone,PC.
3.Supply two verison of software:
  --A.need internet for remote control
  --B.without internet for local control
4.Temperature and humidity automatic control:
  --C.E.g. Temperautre >35℃ Then Device=ON
  --D.E.g. Temperautre <25℃ Then Device=OFF
  --E.E.g. humidity >85% Then Device=OFF
  --F.E.g. humidity <70℃ Then Device=OFF
All trigger conditions and switch control ON/OFF can be set by PC software. Automatic running locally without internet.
  KC868-H32/H32W update firmware by ST-Link USB cable pin define
Posted by: admin - 11-10-2020, 12:57 AM - Forum: KC868-HxB series Smart Controller - No Replies
Here is CPU pin define for ST-Link usb cable to download firmwre.
How to download firmware by ST-link video: https://youtu.be/MI2_qAIEt2U
Photo Unable to connect
Posted by: SAVEE - 11-07-2020, 09:40 AM - Forum: KC868-HxB series Smart Controller - Replies (14)
I followed everything from the pdf file and I am unable to corretcly connect the device and to run it with the software.
Here are the screenshots:
[Image: screen1.png]
[Image: screen2.png]
[Image: screen3.png]
[Image: screen4.png]
[Image: screen5.png]
[Image: screen6.png]
Even if I connect directly on USB on my pc, it doesn't detect it!
Best Regards
Alex
  NodeRed Dashboard Layout of Icons
Posted by: subas - 11-06-2020, 07:23 AM - Forum: Development - Replies (3)
Dear Admin.
How do i change the icon layout on NodeRed Dashboard. Please find screen shot.
If i want to move the 1st LED beside the 1st Switch and move the 2nd LED beside the 2nd switch how do i do it?
  KBOX android phone app updated
Posted by: admin - 11-04-2020, 04:14 AM - Forum: News - No Replies
1. Add support KC868-D8 dimmer controller. Now you can use for LED strip or lamp change brightness and control motor or fan speed.
2. Improve the control speed of relay controller.
Download link: https://www.kincony.com/download/kbox-sm...201104.apk
  KC868-COL
Posted by: James Alabama - 10-31-2020, 01:42 PM - Forum: KC868-HxB series Smart Controller - Replies (12)
KC868-COL locks up and does not respond in the morning or if left for a long period.  I get the following messages:
"Kincony smart controller V.10.303.build 805 (not responding)
JKE_Test not responding (in Task Manager)
If I end the program in task manager and re-load it works fine until next morning and then same problem
Computer Sleep is set to "never"
Any recommendations?
James
  Best Alternative when running Multiple Controles
Posted by: subas - 10-30-2020, 05:50 AM - Forum: KC868-HxB series Smart Controller - Replies (2)
Dear Sir.
What would your recommendation be if I want to run 7 of the KC868-H32W relay board's?
Can the NodeRed handle all 7 Boards reading all the 224 relays ?
I have tried the Demo VB application but that only allows to open 1 application for 1 KC868-H32W relay board's and monitor 32 relays as such i can only monitor 1 KC868-H32W relay board at a time.
If i want to have one screen layout for all 7 KC868-H32W relay showing me at one time what application do you recommend?
  Display Relay Status on NodeRed
Posted by: subas - 10-30-2020, 03:36 AM - Forum: Development - Replies (45)
Dear Sir.
I managed to use the IFTTT on the KC868-COL logical controller.
A very simple test where if the Temperature shows above 33degC Relay 1 turns on at the KC868-H32 relay board's. Both KC868-H32 relay board's and  KC868-COL logical controller are connected via a RS232 cable.
How do show the status of Relay 1 on the KC868-H32 relay board's using a LED on the NodeRed to indicate it's turned "ON"? i don't want to use a Digital in as its a waste of resource. Just a LED on NodeRED reading from the "Function" Node where when its "ON" Led lights up on the NodeRed Screen and when "OFF", LED turns off.
Regards
Subas
  Do the relays support inching switching?
Posted by: admin - 10-30-2020, 01:19 AM - Forum: KC868-HxB series Smart Controller - Replies (7)
Do the relays support inching switching? I need the relay to turn on for 1 second and then automatically turn off.
Answer: Controller's inching switching function support by software. You can create scene mode in our "KinCony smart home" phone app. Also we have "KBOX" local network version app, that can set button for "CLICK" or "TOUCH" mode, that works without internet.
