"KCS" v2 firmware MQTT protocol document - Printable Version
+--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40)
+--- Thread: "KCS" v2 firmware MQTT protocol document (/showthread.php?tid=3105)
Pages: 1 2 3
RE: "KCS" v2 firmware MQTT protocol document - GibKat - 04-07-2024
(04-05-2024, 10:08 PM)admin Wrote:
(04-05-2024, 03:38 PM)GibKat Wrote:
(04-05-2024, 12:06 PM)admin Wrote: why can't input? use mouse click the edit section, then input. if you can't , take a video , send to whatsapp number: +86-15381188302
I can't modify the address, it seems locked (the characters are light gray and not black)
Gray is a prompt message, why don't you try clicking with the mouse and then entering the information????
I have solved. I have disconnected the IR modules before the update of firmware.
RE: "KCS" v2 firmware MQTT protocol document - admin - 04-07-2024
ok
RE: "KCS" v2 firmware MQTT protocol document - sm4l - 04-11-2025
(03-19-2024, 11:13 AM)LTDU Wrote: Is it possible to turn an output on with timer via MQTT? E.g. turn on output1 for 1 second (then turn automatically off)?
You can use Delay option in KCS fw.
Outputs> Type> Delay
Then you configure the delay time.
RE: "KCS" v2 firmware MQTT protocol document - sergiomh96 - 12-01-2025
Hola Señor, es posible enviar ordenes a dispositivos conectados mediante puerto I2C o RS485?
En caso afirmativo, que comandos hay que enviar?
Gracias!!.
RE: "KCS" v2 firmware MQTT protocol document - admin - 12-02-2025
RS485 use by modbus protocol.
here is protocol document: https://www.kincony.com/forum/showthread.php?tid=2528
RE: "KCS" v2 firmware MQTT protocol document - sergiomh96 - 12-02-2025
(12-02-2025, 07:30 AM)admin Wrote: RS485 use by modbus protocol.
Me he explicado mal. Quiero enviar por mqtt un valor leído por modbus, o establecer un valor por mqtt y enviar por modbus.
De igual forma con I2C
Es esto posible?
No, KCS firmware not support that way. if you want, you can write your own arduino code.
RE: "KCS" v2 firmware MQTT protocol document - basilioo - 12-06-2025
(07-24-2023, 03:43 AM)admin Wrote: Note: This protocol document use for KinCony smart controller:
KC868-AM ASR A2 A4 A4S A6 A8 A8M A8S A16 A16S E16S A32 A32M A64 A128 AG AK AI AIO AP
Different board will have different channel of digital output, digital input , ADC, DAC, so the protocol is same , just according to the hardware resource to set channel number.
is there any mqtt command to reboot kc868-a16 board?
RE: "KCS" v2 firmware MQTT protocol document - admin - 12-06-2025
sorry, no this command.
