KC868-UAIR+BME-680 BSEC - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: KC868-UAIR+BME-680 BSEC (/showthread.php?tid=3325) |
RE: KC868-UAIR+BME-680 BSEC - admin - 11-16-2023 1. not need you input clientID for mqtt, it will auto generate. 2. this case, not need to use mqtt, only just create IFTTT command in KCS webpage is ok. for example: set IF temperature>20 THEN send IR1. logical command work in locally is best way. RE: KC868-UAIR+BME-680 BSEC - bsubasi - 11-17-2023 dear admin I have done connecting my uair device to my mqtt broker Sending audio and IR codes with mqtt publish is ok my questions 1) CAN IR & RF LEARNING BE DONE WITH MQTT? 2) CAN HORIZONTAL VERTICAL LEDS BE CONTROLLED WITH MQTT? 3) CAN UAIR MQTT PROCESSES BE DONE WITH ESPHOME. CAN YOU SEND YOUR SAMPLE YAML FILE? thanks & regards RE: KC868-UAIR+BME-680 BSEC - admin - 11-17-2023 1) CAN IR & RF LEARNING BE DONE WITH MQTT? not support 2) CAN HORIZONTAL VERTICAL LEDS BE CONTROLLED WITH MQTT? not support 3) CAN UAIR MQTT PROCESSES BE DONE WITH ESPHOME. CAN YOU SEND YOUR SAMPLE YAML FILE? sure,You can do that, so that question1 and question2 will be available. just use MQTT by esphome config , not by KCS firmware. But esphome is not good with learn IR and RF code. |
