How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - Printable Version
+--- Thread: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO (/showthread.php?tid=1715)
Pages: 1 2 3 4 5
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - GabrielRR - 09-17-2023
Which settings?
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - admin - 09-17-2023
search tasmota source code about the UI files.
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - GabrielRR - 09-22-2023
(09-17-2023, 01:43 PM)admin Wrote: search tasmota source code about the UI files.
Finally I did update the A16 to the last firmware of Tasmota 13.1.
Now everything is working fine, even the inputs are now in the same order, with the difference, that all now are switches.
I did compile the firmware with the option  #define USE_PCF8574_MODE2 where is possible to load a file pcf8574.dat with a template defining all the inputs and outputs as switches and relays only for pcf8574.
Now, there is no need of create rules to connect a input to an output.
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - admin - 09-22-2023
ok, thanks for your result.
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - Als Santa - 10-02-2023
Good day everyone, I am new to Kincony pcbs, I bought 2 boards but they are still on the way, to familiarize myself with my automation I installed the Tasmota BIN file firmware for KC868-A16r on an ESP32 and followed the indicated instructions. I have tried several ways but I can't get the result of seeing or configuring the PCF8574 as it is in the images.
Also support me in the YouTube video:
https://www.youtube.com/watch?v=8NqOW0HJ4EA&ab_channel=KinConyIoT
Lesson29- Tasmota for KC868-A8 by PCF8574 relay and monitor sensor
https://www.youtube.com/watch?v=WCHLYGHKu9g&ab_channel=KinConyIoT
And even on the github page:
https://tasmota.github.io/docs/PCF8574/
https://templates.blakadder.com/kincony_KC868-A16.html
But I still can't.
Could you give me a step by step?
or guide me in what I have failed?
Thank you so much
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - admin - 10-02-2023
you download our A16's tasmota firmware, will see the PCF8574 option, because we have compile the firmware enabled PCF8574 function. if you use your own tasmota firmware, remember to enable it.
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - Als Santa - 10-03-2023
(10-02-2023, 10:07 PM)admin Wrote: you download our A16's tasmota firmware, will see the PCF8574 option, because we have compile the firmware enabled PCF8574 function. if you use your own tasmota firmware, remember to enable it.
Thanks for the help.
I am using your version, but I don't see the PCF8574 option. The firmware is the one at the beginning of this page
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - admin - 10-03-2023
you can do as this: https://www.kincony.com/forum/showthread.php?tid=1715&pid=3084#pid3084
(10-03-2023, 10:59 PM)admin Wrote: you can do as this: https://www.kincony.com/forum/showthread.php?tid=1715&pid=3084#pid3084
I did exactly this, but the PCF8574 does not appear.
"admin Wrote:
these are tasmota firmware BIN file for KC868-A16.
after you download, you need config wifi ssid and password by board's AP.
1. download tasmota download tool for KC868-A16
2. download tasmota BIN file firmware for KC868-A16
3. upload tasmota BIN file on ESP32
what am I doing wrong?
RE: How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO - GabrielRR - 10-04-2023
Use the following template:
{"NAME":"KC868-A16 rev 1.4","GPIO":[32,1,1,1,640,608,1,1,1,1,1,1,1,1,5600,1,0,1,1,5568,0,1,1,1,0,0,0,0,1,1,1,1,1,0,0,1],"FLAG":0,"BASE":1}
on the following menu (dont forget to activate)
[Image: template-import2.png]
