Using ESPHome and HomeAssistant.
Have hooked up a 12v irrigation solenoid (normally closed) to relay 8 but it is getting really hot even when it is off.
I have it wired and coded like this:
12v jumper cable (from the board power) to the (COM) on relay 8
GND jumper cable (from the board power) to the solenoid
(NC) to the solenoid
Thanks,
name: "relay8_solenoid back wall spinkler"
pcf8574: pcf8574_hub_out_1
number: 7 # relay 8
mode: OUTPUT
Thanks,
