11-23-2024, 05:06 PM
Hi Admin, I recently purchased the M16 and 13 SCT013 board, I configured everything with esphome, so far everything is ok. But when I go to read the values of the specific probes, comparing them for example with a PZEM 0-16, I have values in watts very far from the real absorption, I also did a comparison with a clamp meter, and unfortunately the M16 probes all read values much higher than reality. For the voltage I solved it by modifying the file #define SENSITIVITY 525.0f, and now the voltage is correct, but unfortunately for the wattage I can't find a solution, can you help me?
