Error when flashing A32 Pro
im getting this error when im trying to flash my a32pro
as you can see in the picture attached that my config, i hit run, it stays for ever in loading. When i stop this i get
[2024-11-29 20:56:35,958][ESP8266Loader_spi[1]][espDownloader.py][line:422][ERROR]: Chip sync error
[2024-11-29 20:56:35,958][ESP8266Loader_spi[1]][espDownloader.py][line:582][ERROR]: ESP32S3 Chip sync error esp_sync_blocking.
do you using A32 Pro controller, NOT KC868-A32, right?
take a screen photo, what chip type you have chose.
Its says ESP32-S3-WROOM
my means: the ESP download tool first step need you chose chip type. do you have chose ESP32-S3 and USB ?
[Image: esp32-s3.png]
Yes i have done exactly that and it doesnt work....it remains in non stop loading and ingrt the message i posted earlier. Chip blocked
after switching 6 usb cables i was able to flash and add it in home assistant
ok, need use high quality USB-C cable.
