Node-Red flows download for KC868 Smart Controller
Here are some Node-Red flows download link for KC868-Hx relay controller and KC868-COL logical controller in our YouTube video tours.
https://www.kincony.com/download/Node-Red-flows.zip
KC868-COL-logical-controller.json  KC868-COL for Node_Red, to read all digital input , analog input,temperature sensor input data.
KC868-D8-homekit-dimmer.json  KC868-D8 for Node-Red, control dimmer lamp in Apple Homekit
KC868-Hx-relay-controller-home-kit-lamp.json  KC868-Hx relay controller Turn ON/OFF one lamp in Apple Homekit
KC868-Hx-relay-controller-home-kit-32lamps.json  KC868-H32 relay controller Turn ON/OFF 32 channel lamp in Apple Homekit
KC868-Hx-relay-controller-switch-panel-feedback.json  Wall switch panel control lamp synchronous relay state for Node-Red
Could you put similar flows but for MQTT control?
you can use MQTT node, that's very easy, just set the topic and payload. when we have free time, we can make a sample flows.
