What is the Minimal Power Consumption for A16 board
I read that the A16 board requires 1,5A power supply.
However, what is the minimal power consumption of the board?
My requirements are implementable with the ESP32 in deep sleep mode most of the time.
It would be good to implement high availability.
So, for the ESP32, I could implement a USV with a small lithium battery.
How about the periphery?
How much power does it need?
Is it possible to switch of the periphery (I/O pins, USB port, Network)via software?
Thank you
i suggest you use multi meter to test. there are many different case.
(03-16-2025, 11:39 AM)In admin Wrote: i suggest you use multi meter to test. there are many different case.
I’ll report the results here.
Thank you,
Volkmar
(03-16-2025, 08:17 AM)vovo500 Wrote: Hi,
Thank you
https://ibb.co/5h6fYk8S
https://ibb.co/G4yL8X4b
minimium 4.9V stabil 4.9V
thanks share your result.
