Using a different pull-up voltage for GPIO
Hello, I am trying to use very long wires to connect multiple DS18B20 sensors to Kincony A16. I can successfully implement the system using Arduino UNO by providing 5V with a 1k pullup resistor and would like to replicate the same thing with Kincony. How can I achieve the same result with Kincony A16 as it only provides 3.3v pull up?
do you will write arduino code for KC868-A16?
or do you want to use KCS firmware with your multi DS18B20 sensors.
(12-20-2024, 12:55 PM)admin Wrote: do you will write arduino code for KC868-A16?
Would prefer to write arduino code for A16
it's ok, we have tested before.
[Image: attachment.php?aid=1392]
here is demo details: https://www.kincony.com/forum/showthread.php?tid=2290
(12-22-2024, 02:47 AM)admin Wrote: it's ok, we have tested before.
As I am using very long wires, this wiring does not work for my project. I need to externally provide power(voltage) and a different value of pull-up resistor to make this work.
Does the digital pins work like the Arduino's GPIO?
if you want to use for long distance, the best way is chose RS485 sensor.
