updating firmware kc868-h32b
my unit shipped with firmware version 4.13.34
I am attempting to upload version
Relay32_V437_210907.zip
OTA seams to run for only a few seconds and does not update
Using a serial cable and the Firmware Download Tool (firmware update tool download): https://www.kincony.com/download/KC868-C...loader.zip
it detects the bootloader
downloads progress 105/105
data send complete
then when I press Run
it says Download finished begin running.
I power cycle the device that the firmware version is not updated??
thanks
where is say the "firmware version 4.13.34" , take a photo. i think it's your wifi module's firmware version, not controller's firmware.
(03-06-2023, 10:32 PM)admin Wrote: where is say the "firmware version 4.13.34" , take a photo. i think it's your wifi module's firmware version, not controller's firmware.
If this is the Wi-Fi firmware how does one see the controllers firmware?
connect ethernet cable with your controller. open IP address in web browser, then you will see it.
how to update firmware, see this video tour: https://youtu.be/LLIJe9VTVq8
(03-07-2023, 02:10 PM)admin Wrote: how to update firmware, see this video tour: https://youtu.be/LLIJe9VTVq8
Would’ve helped to know that I needed to hold down the ethernet button until all the lights showed in order to turn it into TCP server static mode.
It shows version H32B_V4.29
Is  Relay32_V437_210907.zip a later version , from the numbering v437 looks later than v429 ?
At least I have access to the config , I assumed wrongly this would have been part of the web page available by Wi-Fi.
https://www.kincony.com/forum/showthread.php?tid=2343 this is the newest version V4.46
yes, large number version is newer.
Thumbs Up
(03-07-2023, 10:34 PM)admin Wrote: https://www.kincony.com/forum/showthread.php?tid=2343    this is the newest version V4.46
Relay32_V446_221013.zip
Great that update works, thank you.
ok
