Need firmware with MQTT for Smart dimmer
There will be firmware for Smart dimmer with MQTT
There are no plans at the moment.
We need Smart dimmer MQTT protocol. Because now we don't see the status or ledstripe on or off.
When I turn off the ledstrip with the wall switch, the status of the home assistant in the dashboard does not change.
Do you use Node-Red integrate with home assistant?
Yes I use node-red
now you can place a timer to update dimmer state every some seconds (send read dimmer state command by TCP socket connection). maybe in furture, we will update KC868-D8 for MQTT.
Maybe you can send a sample node red flow configuration?
How to do it, I tried but I don't work for me.
https://www.kincony.com/forum/showthread.php?tid=87 here is Node-Red flows download link, there is sampe KC868-D8 dimmer controller for Apple Homekit integration.
