KC868-A32
Good morning ! I recently purchased the KC868-A32 card. My question is: can Kincony KCS and Home Assistant be used together? Thanks for your help.
sure. you can download KCS firmware firstly , then integrate to home assistant by MQTT.
Thank you very much for your quick response
(12-25-2023, 12:08 AM)admin Wrote: sure. you can download KCS firmware firstly , then integrate to home assistant by MQTT.
Good morning ! How to integrate MQTT into my Home Assistant? Do you have a step-by-step instruction manual? Thanks for your help
this is sample config yaml: https://www.kincony.com/forum/showthread.php?tid=3274
(12-29-2023, 12:13 PM)admin Wrote: this is sample config yaml: https://www.kincony.com/forum/showthread.php?tid=3274
I have a KC868-A32 card. Do you have the yaml file?
THANKS
here is A32 integrate to home assistant by ESPHome's yaml: https://www.kincony.com/forum/showthread.php?tid=1772
we suggest use esphome directly, not need to use KCS.
Hello ! With KC868-A32 I would like to invert the state of the inputs to be ok with the logic state in Home Assistant?
THANKS
if you config by ESPHome, just add "inverted" for INPUT option in yaml file.
(05-04-2024, 11:47 PM)admin Wrote: if you config by ESPHome, just add "inverted" for INPUT option in yaml file.
Thank your very much
