server mini cm4 no don't boot
Hi there,
New server mini, new RASPBERRY-PI  CM4108032  Raspberry Pi 8GB Compute Module 4 with WiFi, 32GB eMMC, new 24v ps, when I power it up it does not even connect to my switch...
a
do you have installed software for your CM4?
if new controller, there is no firmware. Do you want to install home assistant or Node-red software?
I folowed your youtube instruction, installed home assistant, tried 3 different sd card...
you are using CM4 with eMMC version, so can't use SD card, only can use eMMC. if you use CM4 lite version, you can use SD card.
