07-03-2024, 08:11 AM
Translator
I would like to know whether the following project is possible and what people think about what I need to order:
I would like to control a rain sprinkler system via home assistant. I think I need a board that is controlled with Ethernet and can control 4-6 relays 24 volt "Hunter 24vac valves (magent coil)".
I would like to have an optional switch, for example
hhttps://shop.kincony.com/products/touch-switch-panel-dry-contact-signal?variant=43573355511973 or hhttps://shop.kincony.com/products/8-gang-wall-toggle-reset-switch-push-button-momentary-contact-for-smart-home-automation-diy
If necessary, you can control the release without a home assistant or an app.
Thank you
Dennis
Thank you
Dennis
