01-28-2022, 01:03 PM
Hello, I would like to know if it is possible to use the RS485 port to receive the reading data from a pzem 017 dc to integrate with the Home Assistant using MQTT. Thanks.
KC868-H32BS v 1.44 x PZEM 017 DC
01-28-2022, 11:58 PM
no, the RS485 of H32BS is "slave" mode, use for integrate by other "master" device.
01-31-2022, 04:55 PM
OK, Thanks.
02-01-2022, 06:56 AM
(01-31-2022, 04:55 PM)rodrigomallmann Wrote: OK, Thanks. Hi. Probably it's possible with COLB, but only with Node-Red. Sadly there is no flow available for this. I have a Kincony energy meter and a COLB device, the data flows in to COLB but cannot use in Home Assistant without the above mentioned Node-Red flow.
02-01-2022, 12:30 PM
if you use Node-Red on raspberry pi, i suggest you use a USB-RS485 adapter, let pi connect with kincony power energy meter directly, the meter use by MODBUS protocol , easy to integrate with home assistant, not need via COLB.
