I bought it and used it, but it doesn't work.
I put the code on esphome and turned on the switch, but the led doesn't light up.
i use this code
platform: ESP32
sda: 4
scl: 5
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
# Use pin number 0
# One of INPUT or OUTPUT
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_out_2
# Use pin number 0
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_in_1
# Use pin number 0
inverted: false
pcf8574: pcf8574_hub_in_2
# Use pin number 0
inverted: false
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "xxxxxxxxxxxxxxx"
password: "xxxxxxxx"
captive_portal:
i use this code
platform: ESP32
sda: 4
scl: 5
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Use pin number 0
mode: OUTPUT
inverted: false
# Use pin number 0
mode: OUTPUT
inverted: false
# Use pin number 0
inverted: false
# Use pin number 0
inverted: false
encryption:
ota:
wifi:
ap:
captive_portal:
