sda: 4 #replace by your board's pin define
scl: 5 #replace by your board's pin define
address: 0x24 #replace by your PCF8574 address
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
download yaml demo for ESPHome:
DO8_config_yaml.txt (Size: 1.58 KB / Downloads: 186)
about A0,A1,A2 i2c address setting:
A0 A1 A2
0 0 0 =0x20
0 0 1 =0x21
0 1 0 =0x22
0 1 1 =0x23
1 0 0 =0x24
1 0 1 =0x25
1 1 0 =0x26
1 1 1 =0x27
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
A0 A1 A2
0 0 0 =0x20
0 0 1 =0x21
0 1 0 =0x22
0 1 1 =0x23
1 0 0 =0x24
1 0 1 =0x25
1 1 0 =0x26
1 1 1 =0x27
