06-28-2023, 01:59 PM
I've defined the digital inputs and switches as in the example and also added a DS18B20 temp sensor to the I2C. But as soon as I add in yaml the Dallas configuration, the update_interval toggles the switches on and off at the interval set in the update_interval.
I saw that the I2C port is the same as the Dallas sensor but I don't know how I can connect them in a different way.
friendly_name: Kincony KC868-E16S
platform: ESP32
captive_portal:
sda: 16
scl: 15
address: 0x21
address: 0x25
address: 0x22
address: 0x24
pcf8574: pcf8574_hub_out_2
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
name: "DI1 - Entrance Left B1"
pcf8574: pcf8574_hub_in_2
number: 7
internal: true
on_press:
then:
- switch.toggle: output14
dallas:
- pin: 16
update_interval: 30s
- platform: dallas
address: 0x453c430457d4c928
name: "Livingroom Temperature"
- platform: dallas
address: 0x9d3c450457bfc728
name: "Bedroom Temperature"
platform: ESP32
captive_portal:
sda: 16
scl: 15
address: 0x21
address: 0x25
address: 0x22
address: 0x24
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 7
internal: true
on_press:
then:
dallas:
- pin: 16
- platform: dallas
- platform: dallas
