Control defaults to TCP after power cut
Hi there
I have an issues with the KC868-Server unit. The unit is set to MQTT work mode, but sometimes after a power cut the controller reverts back to TCP mode. How can I set it to always start in MQTT mode?
what's your firmware version?
Ill update the firmware for this device and test again. Which firmware is the correct version for the KC868-Server unit, is it the 32BS?
i don't understand which controller you are using? KC868-Server or KC868-H32BS?
