KCS Firmware and home assistant together ?
Hello !
Is there a way to run KCS Firmware and home assistant simultaneously?
sure, download KCS firmware to ESP32, then use MQTT integrate to home assistant.
Well that's a solution but unfortunately not what i'm looking for.
For my use case I have an A32 board pro with integrated Sim module, I want to access and use that SIM module as action trigger when sms recived from home assistant. to you have any idea how to get access and use that sim module directly from HA ?
have a nice day Smile
maybe you can try this: https://github.com/esphome/feature-requests/issues/1810
Thank you i'll give you a try,
Last question : do you have a ready yaml file fo HA MQTT integration to A32 board ?
you can see this, this for A8S board : https://www.kincony.com/forum/showthread.php?tid=3274
but it's as same as A32's yaml.
