Jogging
How does output work in "jogging" mode?
I don't see any diffrence with "hold on" mode.
what KCS firmware version you are using?
Board Model KC868_A16
Software Version v2.2.4
Build Date Jun 18 2024 13:52:03
Serial Number 08A6F74A6528
KCS v2 no "jogging" option. because you can create IFTTT command for "jogging" function. let digital input button pressed THEN relay ON, when released THEN relay OFF.
So the jogging option in the output settings was left by mistake?
you are using KCS v1 firmware.
the KCS v2 firmware no this option, here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
I use firmware 2.2.4
This is just from your online guide
jogging option is "invalid" in KCS v2 version, just create IFTTT for "jogging" .
