12-09-2024, 03:43 PM
I`m Trying to integrate AG8 with SmartIR project. It uses "remote" entity to transmit raw data from homeassistant directly to device.
https://github.com/smartHomeHub/SmartIR
I had sucess using broadlink rm4 pro transmiter, but AG8 entity do not appear at homeassistant remote entities:
I`m using following yaml file:
Device work just fine with other functions:
Only remote.ag8-teste entity is not working.
Anyone has an idea what could be my mistake ?
I`m using updated version possible:
I appreciate all kind of help.
friendly_name: ag8-teste
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: esp-idf
sdkconfig_options:
SOC_RMT_SUPPORT_RX_PINGPONG: "n"
wifi:
ssid: !secret wifi_ssid
remote_receiver:
pin: 48
rmt_channel: 4
dump: all
remote_transmitter:
- id: ir1
pin: 9
carrier_duty_percent: 50%
rmt_channel: 0
- id: ir2
pin: 10
- id: ir3
pin: 11
- id: ir4
pin: 12
- platform: template
turn_on_action:
- remote_transmitter.transmit_panasonic:
transmitter_id: ir1
address: 0x4004
command: 0x8140DFA2
turn_on_action:
transmitter_id: ir2
address: 0x4004
command: 0x8140DFA2
turn_on_action:
transmitter_id: ir3
address: 0x4004
command: 0x8140DFA2
turn_on_action:
transmitter_id: ir4
address: 0x4004
command: 0x8140DFA2
- platform: uart
uart_id: uart_485
- platform: uart
uart_id: uart_232
data: "RS232-test"
uart:
- id: uart_485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 18
rx_pin: 8
- id: uart_232
baud_rate: 9600
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
tx_pin: 17
rx_pin: 16
number: 15
mode:
input: true
pullup: true
number: 38
mode:
input: true
pullup: true
number: 39
mode:
input: true
pullup: true
number: 40
mode:
input: true
pullup: true
web_server:
port: 80
- Core2024.12.1
- Supervisor2024.11.4
- Operating System14.0
- Frontend20241127.6
- ESPHome addon: 2024.11.3
