KC868-A32 wiring diagram
Which pin to connect the ds18b20 temperature sensor to?
if you want connect DS18B20, you can connect to extend serial port GPIO on the PCB.
Good day,
How do I output 12/24V for LED? Just replace light bulb in the diagram with 12/24V power supply and LED?
yes, you are right.
Thank you very much.
How should I wire an AC-AC contactor? Do I need RC Snubber? I want to control a 20A water heater. Thank you every much.
if you want to use AC-AC contactor, just let A32's relay output AC220V to contactor's coin. KC868-A32 designed PCB can work without RC snubber.
Is the screws terminal for this board 3.81mm or 5.08mm? I mean something like this:
https://www.aliexpress.com/item/1005007634896358.html
In my project the wires have to come in from the side.
I want to know if 3.81mm or 5.08mm will fit on A32. Thank you very much.
if you are asking relay output green terminal, it's 5.00mm, NOT 5.08mm.
