11-28-2024, 11:00 PM
"Is it possible that in 1 yaml file to program bought gpio15 an gpio 16 leds?" what this means? you can control both LED with GPIO15 and GPIO16, it's OK.
AS ESPHome yaml for home assistant
12-02-2024, 05:18 PM
I recently purchased and setup the KinCony Voice Assistant device. Works great, but the volume from the speaker is too low to hear. How can I increase the volume from the speaker?
12-02-2024, 10:59 PM
if you use ESPHome, you can set the volume in yaml file.
12-05-2024, 03:35 PM
12-05-2024, 11:21 PM
12-20-2024, 04:03 PM
Hi all,
I have my working configuration here, also using media player: Code: esphome: May help someone, it took me 3 days to make it working
12-20-2024, 11:29 PM
Thank you very much share your config file to help people.
12-27-2024, 03:51 AM
(12-05-2024, 11:21 PM)admin Wrote: see here in details: https://esphome.io/components/speaker/index.html So I have this file: /homeassistant/esphome/kincony-as.yaml and I've modified the speaker section to: speaker: platform: i2s_audio id: va_speaker i2s_audio_id: i2s_speaker volume: 90% dac_type: external i2s_dout_pin: GPIO8 # DIN Pin of the MAX98357A Audio Amplifier channel: mono Then did a quick reload of the YAML, then restarted Home Assistant, but no change in volume. Is there something else I need to do please?
12-27-2024, 04:16 AM
(12-05-2024, 11:21 PM)admin Wrote: see here in details: https://esphome.io/components/speaker/index.html Think my previous reply was not following the example, so also tried this: speaker.volume_set: 90% and this: speaker.volume_set: id: va_speaker volume: 90% Still no change
12-28-2024, 01:23 AM
sure, you can control GPIO15 and GPIO16 different LEDs. see this demo video: https://www.youtube.com/shorts/59CFvpFJMdc
Users browsing this thread: |
