RS485 Modbus working ESPHome configuration
Hello everyone!
I wanted to share my ESPHome configuration for interfacing with a solar charge controller (Epever LS1024B) using RS485.
This setup allows to read the PV voltage from the controller's register.
Below is the working configuration that I used, which may help others facing similar challenges.
# UART configuration
uart:
  - id: rs485
    tx_pin: GPIO27
    rx_pin: GPIO14
    baud_rate: 115200  # Baud rate
    data_bits: 8       # Data bits
    stop_bits: 1       # Stop bits
    parity: NONE       # No parity
# Modbus configuration
modbus:
  send_wait_time: 200ms
  uart_id: rs485
# Modbus controller configuration
modbus_controller:
  - id: charge_controller
    address: 0x01
    modbus_id: mod_bus
    command_throttle: 100ms
    setup_priority: -10
    update_interval: 300s  # Update interval
# Reading register 0x3100
  - platform: modbus_controller
    name: "Solar Charge Controller PV Voltage"
    address: 0x3100
    register_type: read
    accuracy_decimals: 2  # Decimal accuracy
    unit_of_measurement: V
    filters:
      - multiply: 0.01  # Scale factor based on charger specs
I hope this helps others in the community.
thanks share your result.
