KC868-HA-V21 serial port selector drop box freezing
Bug
Hi admin,
    when I click the serial port drop box, the app doesn't respond anything, it is freezing. I have already installed CH341 driver on my laptop for rs485 to usb config device. It showing the correct com port when I checked in device manager. But, I can't select the serial port in the app. I m using windows 11. Help me with that.
I m sure KC868-HA-V21 module is working normal. It is sending some data frame when I press k1 button in the serial monitor.
i think maybe windows problem. can you run our software by administrator mode. close all firewall. or you can use another computer for a testing.
(Yesterday, 12:13 AM)admin Wrote: i think maybe windows problem. can you run our software by administrator mode. close all firewall. or you can use another computer for a testing.
Alright, will do it.
Are there any way to config the RS485 button module without using this config application?
Can I program the module using some IDE ?
I have tried it using another computer like you said. It is not working.
