Need Advice for New 3-Floor Smart Home Construction Using KinCony Controllers (Nepal)
Hi everyone ❤️,
I am from Nepal and will start building my new house this month. another controller, which is best for 2 floors, there are many channels needed for 50 channel need for 2 floors
I already have a KinCony AIO controller and would like to plan the smart home wiring before construction begins.
I have attached my floor plan. Could you please suggest:
  • Best switch type (momentary/dry contact)
  • I want to bypass the switch also
  • I place the floor-wise DB box and want to install it
  • Recommended sensors (presence, motion, door, water leak, smoke, etc.)
  • RS485 wiring recommendations
  • Any important things I should install now for future expansion
Any suggestions or examples would be greatly appreciated.
Thank you very much! ?
Jitendra
Nepal ??
By the way, I lived in Japan. If any person from Nepal wants to import easily,
.pdf   Top Floor Plan.pdf (Size: 10.63 KB / Downloads: 248)
.pdf   Second Floor Plan (1).pdf (Size: 46.44 KB / Downloads: 249)
.pdf   Ground Floor Plan.pdf (Size: 48.52 KB / Downloads: 234)
.pdf   First Floor Plan (1).pdf (Size: 53.51 KB / Downloads: 228)
i think every floor you can make a smart DB. just you need calculate the channels, then chose BxM series smart controller + DC contactor.
(06-18-2026, 02:47 PM)jitendra Wrote: Hi everyone ❤️,
Jitendra
Nepal ??
Hi Jitendra,
Strategic Hardware Architecture and Connectivity Recommendations for KC Controller Deployment and Network ResilienceIt is recommended to deploy
a decentralized architecture utilizing multiple small to medium-sized controllers rather than a single centralized unit.
This approach significantly reduces cable routing complexity across the infrastructure. Integrated system components will connect via Wi-Fi or Ethernet,
leveraging IFTTT or standard TCP/IP protocols for seamless interoperability. A critical advantage of this topology is network resilience:
in the event of a network outage, all KC controllers will continue to operate independently in standalone mode.
While the initial capital expenditure may be higher, this investment guarantees long-term system redundancy and operational reliability.
Furthermore, implementing RS485 serial communication alongside multi-gang switches will minimize wiring overhead from wall switches to
the KC controllers.Sensor Selection and Signal IntegrityFor environmental and security monitoring, each room should be equipped
with 24GHz presence sensors, smoke detectors, and window contact sensors. Where feasible, LoRa-based (Long Range) sensors should be prioritized.
LoRa technology provides superior immunity to radio frequency (RF) interference, ensuring stable data transmission in dense wireless environments.
This robust framework establishes a highly resilient, scalable foundation for the Home Assistant deployment
Happy building your home assistant project.
Best regards
Zali
Best regards
Zali
