led doesn't light up
I bought it and used it, but it doesn't work.
I put the code on esphome and turned on the switch, but the led doesn't light up.
i use this code
  platform: ESP32
  sda: 4
  scl: 5
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_in_1
      # Use pin number 0
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      inverted: false
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "xxxxxxxxxxxxxxx"
    password: "xxxxxxxx"
captive_portal:
do you have connect power with MOSFET output's terminal?
need connect with DC12V, every 8 channel MOSFET output use a common DC power supply input.  see "12/24V DC input" in photo.
[Image: KC868-A16-1_03.jpg]
thanks so much its work
is there no 16-channel Arduino coding?
there are many arduino IDE demo source code, you can download at here: https://www.kincony.com/forum/forumdisplay.php?fid=25
[Arduino IDE demo source code for KC868-A16] series topic.
I am looking for a code to control 16 channel MOSFETs with Arduino mqtt communication~
i couldn't find
you can modfiy with this demo source code: https://www.kincony.com/forum/showthread.php?tid=1843
this is KC868-A4 wifi work with MQTT, you just need add I2C code for mosfet output with A16.
THANKS YOU SO MUCH
you are welcome
