KS868-A Series multiple questions
just a fest questions about different A-Series ESP32 controllers:
1. Are the dry contact inputs of the KCS868-AI the same as on the KC868-A16/64/128 ? (anti-interference, ling range etc)
2. Can the dry contact inputs of KCS868-AI or KC868-A16/64/128 also be driven by external voltage, such as +5V or +12V?
3. Can the MOSFET outputs of KC868-A16/64/128 also drive +5V instead of 12V/24V?
4. Can the MOSFET outputs of KC868-A16/64/128 drive different voltages per 8-PIN-Block? For example 12V output on A1-A8, 24V output on B9-B16, 5V output on B73-B80?
1. yes, all KC868-A series board digital input is same.
2. dry contact input can work for +12v , that means logical "1", acutally >5v for logical "1" is stable.
3. sure, just every 8 channel have "Vin" , you can connect with different voltage, so that mosfet will output different voltage.
4. sure, you are right. every 8 channel mosfet use by one power supply independently.
Thank you,
so just to make sure again:
1. Driving +5V MOSFET output ist OK?
2. What is the MOSFET output voltage RANGE?
1. yes, it's ok.
2. RANGE= 5v---24v DC
