A24 arduino demo source code-06- Ethernet LAN8720 by UDP
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
#define ETH_TYPE       ETH_PHY_LAN8720
#define ETH_CLK_MODE   ETH_CLOCK_GPIO17_OUT
WiFiUDP Udp;                      //Create UDP object
unsigned int localUdpPort = 4196; //local port
// Set it based on the IP address of the router
IPAddress local_ip(192, 168, 1, 200);
IPAddress gateway(192, 168, 1, 1);
IPAddress dns(192, 168, 1, 1);
void setup()
  Serial.println();
  ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE); //start with ETH
  // write confir for static IP, gateway,subnet,dns1,dns2
  Serial.println("Connected");
  Serial.print("IP Address:");
  Udp.begin(localUdpPort); //begin UDP listener
void loop()
  int packetSize = Udp.parsePacket(); //get package size
  if (packetSize)                     //if have received data
    char buf[packetSize];
    Udp.read(buf, packetSize); //read current data
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.println(Udp.remoteIP());
    Serial.print("From Port: ");
    Serial.println(Udp.remotePort());
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort()); //ready to send data
    Udp.print("Received: ");
    Udp.write((const uint8_t*)buf, packetSize); //copy data to sender buffer
    Udp.endPacket();            //send data
A24 arduino demo source code-06- Ethernet LAN8720 by UDP - by KinCony Support - 12-07-2023, 02:39 AM
