Lights are not turned on if the dimmer is off button is pressed shortly
It seems I am too stupid to use the dimmer KC868-D8 with the firmware version 4.37
Flashing and so one was successful and now I started to test the dimmer keys.
I made the settings:
- Switcher Workmode: 1 Key
- Remember Last State: No (based on your last reply)
Connected K1+ with KCOM as a test:
[Image: dimmer-connect.png]
Behavior:
1. Long Press on the button => Normal behaviour the dimmer goes up and down as described ✅
2. If the light is on, then "short press" on the button => Normal behavior the dimmer value goes down to 0 ✅
3. If the light is off, then "short press" on the button => Faulty behavior the dimmer value does not change at all! ❌
My expectation is the same as in the video https://youtu.be/MdCBQl_y4f8?si=68JOT1UzzXkuaNfm&t=605
which means: "short press" when the lights are off should result in setting the dimmer to 99.
Anyone else with this problem?
Lights are not turned on if the dimmer is off button is pressed shortly - by iwzr - 04-10-2024, 01:19 PM
