using 5v-12v as input sensor
i just want to double check before i burn the board Smile
Are you sure it's a dry contact? the  E3F-DS30P1 is a PNP that have just 3 wires and the output voltage is the same as the input. (sorry, i'm not electrician)
meaning that if the input is 12v, the output will also be 12v.
i have several similar devices working in different voltages can you confirm the following?
1. will 5V entry on digital input port is OK?
2. will 12V entry on digital input port is OK?
3. will 24V entry on digital input port is OK?
[Image: PHI1072896-E3F-DS30P1-PNP-Photoelectric-...pen-02.jpg]
thanks
using 5v-12v as input sensor - by amararsa24s - 09-08-2024, 11:05 AM
RE: using 5v-12v as input sensor - by admin - 09-08-2024, 11:26 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-09-2024, 07:08 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-09-2024, 06:10 PM
RE: using 5v-12v as input sensor - by admin - 09-09-2024, 11:03 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-10-2024, 07:32 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-11-2024, 05:08 PM
RE: using 5v-12v as input sensor - by admin - 09-11-2024, 11:42 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-12-2024, 06:31 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-14-2024, 11:11 PM
RE: using 5v-12v as input sensor - by tanoshimi - 02-01-2025, 03:01 PM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 12:13 AM
RE: using 5v-12v as input sensor - by admin - 02-02-2025, 12:39 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 09:28 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 10:04 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 10:26 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 10:35 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 10:44 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 11:21 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 07:47 PM
RE: using 5v-12v as input sensor - by twostar - 02-03-2025, 03:44 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-03-2025, 07:56 AM
RE: using 5v-12v as input sensor - by admin - 02-03-2025, 05:32 AM
RE: using 5v-12v as input sensor - by twostar - 02-03-2025, 05:35 AM
