Lesson21- KC868-A8 ethernet work with home assistant by ESP home
here is ESP home config file work with KC868-A8 by ethernet static IP:
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.2.199
    gateway: 192.168.2.1
    subnet: 255.255.255.0
  - id: 'pcf8574_hub'
    address: 0x24
# Individual outputs
      pcf8574: pcf8574_hub
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
Lesson21- KC868-A8 ethernet work with home assistant by ESP home - by admin - 10-05-2021, 11:34 AM
