HC868-AK firmware update
(11-24-2024, 09:46 PM)admin Wrote: the newest KCS v2 config IFTTT webpage, let every button output customize RS232 command output.
so you need create 32 IFTTT command for every button. such as :
button1 (DI1) output command "RELAY-SET-255,1,1" by RS232 or RS485.
just to see if I am making some mistakes.
1. I need to go under general and enable custom protocol (e.g., create a new general protocol with ID 1) with router RS232 and output command RELAY-SET-255,1,1
2. I need to go under IFTTT and create a new rule which if D1 is pressed then it triggers the general protocol 1 that I created
3. under protocol --> general I need to enable the RS232 with baud 115200, stop bit 1, data bit 8, parity no.
Perhaps I am missing something because it is not working.
thanks
also, how to I get back the original firmware (non KCS)?
HC868-AK firmware update - by leliodm - 11-23-2024, 03:25 PM
RE: HC868-AK firmware update - by admin - 11-24-2024, 01:38 AM
RE: HC868-AK firmware update - by leliodm - 11-24-2024, 06:22 PM
RE: HC868-AK firmware update - by admin - 11-24-2024, 09:46 PM
RE: HC868-AK firmware update - by leliodm - 11-25-2024, 12:06 AM
RE: HC868-AK firmware update - by leliodm - 11-25-2024, 02:38 AM
RE: HC868-AK firmware update - by admin - 11-25-2024, 07:37 AM
