I bought the KC868-A16 recently and I worked with it for a few days to set it up with Home Assistant; now I finally have it set up so I can connect my devices to the outputs and switch them on/off (one at a time) using home assistant.
The problem I am now having is that when I try to switch on more than one device at a time (each connected to a different output on the KC868-A16), the devices will not get enough power and they will switch off automatically through the KC868-A16 after a second or so.
Each of my devices requires 12 Volts and 3 Amps of power. I currently have 12 devices in total. What do I need to do in order to give adequate power to all devices at the same time, assuming I have connected them each to a different output, and without them losing power? I have only tried two devices at once and that didn't even work - only one device at a time can receive enough power to stay on.
