12-06-2024, 02:14 PM
I'm sorry, I don't fully understand, do I need to purchase 2 additional separate power supplies, and connect one to each of the 8-output blocks (12V x 8 = 96 volts to each side)? I've already connected the ground wires of both siren devices together via the terminal block seen in the picture.
Or, would this be eaier/safer if I somehow connected a separate relay module board, or would I need a different device altogether, such as the KC868-A16S relay board?
I don't have very much experience working with electronics boards and the correct ways to connect and power devices; most of my prior experience is working with the software instead, i.e. Home Assistant, and wireless plug-and-play devices. For this project, all I want is the ability to switch on/off multiple wired devices using Home Assistant, ensuring each device has enough power so that they can all be switched on at the same time.
