Esphome invalid config KC-868 A8
In KC-868 A8 in EspHome I have problems setting up the switch component.
I want that when I press digital Input#1 then relay #1 Toggles.
PCF8574 I/O Expander uses I2C Bus to set IDs, probably that is why the YAML validator don't recognizes the ID of light1? I don't know.
I know I can link the inputs and the relays in HomeAssistant, but I want the logic to be coded in the board so It still works if Internet brokes.
I also know that KCS firmware allows that requirement, but I am looking for an EspHome solution.
Thank you
EspHome Config:
  platform: ESP32
  sda: 4
  scl: 5
ota:
  - platform: esphome
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - id: 'out'  # for output channel 1-8
    address: 0x24
  - id: 'in'  # for input channel 1-8
    address: 0x22
      pcf8574: out
      mode: OUTPUT
      pcf8574: in
    on_press:
      then:
        - switch.toggle: light1
Yaml Validator Output:
Esphome invalid config KC-868 A8 - by Lory - 12-09-2024, 06:48 PM
RE: Esphome invalid config KC-868 A8 - by admin - 12-09-2024, 10:20 PM
RE: Esphome invalid config KC-868 A8 - by Lory - 12-09-2024, 10:37 PM
RE: Esphome invalid config KC-868 A8 - by admin - 12-09-2024, 10:53 PM
RE: Esphome invalid config KC-868 A8 - by MariusM - 12-10-2024, 02:57 PM
RE: Esphome invalid config KC-868 A8 - by admin - 12-10-2024, 11:56 PM
RE: Esphome invalid config KC-868 A8 - by MariusM - 12-12-2024, 11:38 PM
RE: Esphome invalid config KC-868 A8 - by admin - 12-13-2024, 01:00 AM
RE: Esphome invalid config KC-868 A8 - by Lory - 02-16-2025, 12:50 PM
RE: Esphome invalid config KC-868 A8 - by admin - 02-17-2025, 12:35 AM
RE: Esphome invalid config KC-868 A8 - by Lory - 02-23-2025, 06:45 PM
RE: Esphome invalid config KC-868 A8 - by admin - 02-24-2025, 12:08 AM
